Hi There,
I am attempting to receive an NDI input from OBS. I am getting the following message...
"Attempting to load video stream. The stream is not available yet or an error occurred. Retry manually."
It was working well yesterday. Not sure what changed.
Anyone know how to fix this?
NDI Live Stream input is not working
projectneptune
Re: NDI Live Stream input is not working
Is the NDI source on the same machine as Resolume or on a remote computer connected to Resolume via ethernet?
Doesn't look like an NDI issue/message, your first screenshot is from OBS?
What kind of stream is your source in OBS?
projectneptune
Thanks, ya'll!
Shortly after I posted this OBS crashed, and when I restarted it, the feed worked once more. So it seems like this was an OBS issue.
OBS is capturing video from OBS.Ninja on a separate machine, and then sending out discrete NDI feeds over network to Resolume.
Appreciate the prompt responses!
