External Audio FFT trigger
Noralie
Post by Noralie »
Hi There,
Since I work a lot with classical/ analog music I would love to find a way to use external audio to trigger cue points or control the speed/timeline. I figured you can control the master comp speed with external fft but it would be great if you can link it to one single clip and even trigger cuepoints. Does anyone know a plugin for this?
Re: External Audio FFT trigger
Check out http://benjamin.kuperberg.fr/chataigne/en ;)
Noralie
Post by Noralie »
This is amazing thank you!!! :o
Zoltán wrote: Thu Oct 29, 2020 08:40 Check out http://benjamin.kuperberg.fr/chataigne/en ;)
