full dome master preparation
noBIGego
Post by noBIGego »
Hello - I plan to VJ in a planetarium in a few months and will have to create a full dome master (fish eye)
At this initial point of the project I am testing the workflow for the project.
When working with 2d 4k clips (not 360 equirectangular) I follow this process in After Effects (vr convertor - input equirectangular and output fisheye (full dome).
This does not seem to work with a 4k file but seems to work fine when using a 1080p video file.
any feedback is appreciated,
thanks
James
mowgli
Re: full dome master preparation
Post by mowgli »
I suggest you use the plugins here: http://fulldomevjs.com/fdvj/ and avoid AE altogether. There's no reason to prerender when you're using a live real-time video app. This will allow you to tweak as much as you like without the long render times plus it will open up limitless possibilities.
