ATI or nVidia
ATI or nVidia
I'd like to ask which graphic card (chip) is better ATI or nVidia (GeForce), pls help me with this problem
continuity-B
SuperficiaL
in my oppinion it comes down to this...
NVidia is to "Fischer Price" for me.
ATI has some known settings problems but when u get the right settings they work great!
ATI Radeon 8900 PRO is my choice.
Superficial...
Superficial...
continuity-B
Anonymous
continuity-B
Generic fix for a lot of issues...
Install latest drivers (AFTER uninstalling old ones). The ATi ones are very good now, although if you still have problems try the Omega drivers.
Uninstall/reinstall resolume is recomended after new drivers - sometimes hangs on startup I find if you dont plus it's very quick to do anyway.
Specific problems..
Does resolume alone freeze, or is it your whole machine? If it's the whole machine, can you monitor your CPU temp? Sounds like overheating perhaps.
I have SP2 on my machine (it was an accident) and to be honest resolume runs fine (turn all the bells and whistles like firewall, virus monitor off remember). What knocks it sometimes (I think) is automatic updates, which occasionally have required me to reinstall everything as above to get working again.
[Edited on 3-11-2005 by continuity-B]
Specific problems..
