BPM sync malfunction
dgodd
Post by dgodd »
Hello,
BPM sync seems to be malfunctioning again. This time, it is stuck as if on "pause" even when the forward/back arrows are pressed. Hitting play/pause also has no effect.
Will use timeline in the meantime - just wanted to give a heads up!
7.3.0 rev 72441
Re: BPM sync malfunction
Could you upload a screen recording of this showing the whole UI, and param settings including the Start options?
dgodd
Post by dgodd »
I'm a goon
The whole composition was paused :D
That would explain it then ;)
