Clip render with images
dgodd
Post by dgodd »
Howdy
I'm curious if there is a way to incorporate animated parameters while using the clip render feature?
I love playing with images inside Resolume; However it seems that when using clip render on images, the length of the rendered clip is basically 0.
Does clip render only apply for the playback time of the source file?
Edit: As a side note - I'm also not sure if this is the proper sub forum for questions, or if those are meant to be posted in the suggestions forum.
Re: Clip render with images
Yes, parameters you animate on the clip, should also animate offline, when the rendering happens in the background, so their effects will be visible in the render.
Still images have a default duration of 1 seconds, which doesn't really matter if you play the clip, as it loops.
You can change the duration in the clip panel in the Transport section, then the render will folow that.
dgodd
Post by dgodd »
Thank you so much!
Changing the duration was exactly what I was looking for!
