Changing clip speed automatically / over time?
apahualpa
Post by apahualpa »
Hello. I'm wondering if it's possible to somehow achieve the following:
Say there's a 10minutes long videoclip. You want to play it so, that it plays for 5 seconds in 1x speed, then 50 seconds of the original clip at 10x speed, then the same again. So the result/output would be that the clip plays every other 5secs at normal rate and every other 5secs at 10x rate. How to achieve? Thru some osc magic?
Thanks and regards
He2neg
Re: Changing clip speed automatically / over time?
Post by He2neg »
though envelope (and the speed dial) inside arena without external stuff needed ;)
or did you try that allready and it didnt work, becouse of.... (tell us pls) ?
~Berlin~
apahualpa
Post by apahualpa »
It seems there's no option to use timeline/envelope on the speed control in the transport section of a clips properties. Thus my question.
apahualpa
Post by apahualpa »
Oh, my bad :D The composition speed can be adjusted with timeline/envelope even tho clip speed can't. But this is no help if you are rendering the clip (to make a new clip with speed adjustments) so the topic still remains..
apahualpa
Post by apahualpa »
Of course you could use the recording function but the result might not be that smooth. Tho it helps to have the source clip in dxv format to achieve smoother result.. Would be awesome to have "render composition" function :mrgreen:
Indeed animating clip speed is not possible at this time. Moved to feature requests ;)
What you could try would be duplicating the clip, then setting the ranges on the clip you'd like to play with different speeds, and use auto pilot to advance the clips: https://resolume.com/support/en/clips#auto-pilot
He2neg
Post by He2neg »
my bad... i´m used to think that all parameters can be animated and can be set wit envelope....
~Berlin~
