Problem with MidiVid Codec
SiliconCarney
Post by SiliconCarney »
I've recently installed a new system specialy to use Resolume. But, after installation of MidiVid Codec, all the MidiVid compressed footages are not recognized by Resolume and BSPlayer. On a other system (my WinXP that I using for others tasks - Internet, etc...) Midivid is correctly running. Both versions of WinXP are WinXP Pro SP2, but the Resolume dedicated system is not updated because there is not internet connexion on this PC. Maybe it's the problem ?
Thanks !
Silicon Carney from France.
it,s always a good idea to ru the latest windows versions; you can also download the Service Packs, burn them to a cd and then install on your Resolume machine. Hope this helps.
Anonymous
Post by Anonymous »
here's the solution : you must NOT make an AVI2.0 compatible file
just uncheck this and you are ok
gpvillamil
Post by gpvillamil »
If you have ffdshow running on that machine, make sure you disable MJPEG support in ffdshow. That will let midivid handle the decoding instead.
