Black frame avi with premiere?
CitySinner
Post by CitySinner »
I'm using Adobe Premier to produce avi loops for resolume..I'd like to know which is the best resolution to export avi files in order to play them with resolume and not to hove this bloody black frames all around my loops....
[Edited on 8-11-2005 by bart]
sounds like a problem with premiere not a resolume problem. you could try VirtualDub if Premiere is not giving you any love.
Anonymous
Post by Anonymous »
try using the motion effect in resolume to zoom in on your clip to get around this problem - also if you use the safe framing tool it makes life easier to get the amount of zoom required correct
Anonymous
Post by Anonymous »
sorry motion effect tool in premiere - doh - its been a long day :P
