Display indexes in Advanced Output change after restarting Windows 10
Enrique E.
Post by Enrique E. »
Hello all!
I working in an installation with 4 projectors and an extra service terminal for a permanent installation. But sometimes, randomly, the display configuration changes when restarting the computer.
All the displays are connected to a Sapphire Pulse Radeon RX 580 graphic card, and wake up on signal when the computer is switched on.
I know that for the indexes of multiplay displays, Resolume uses the information from the OS, in this case Windows 10. I would need to save the display configuration based on the physical outputs of the graphic card, not on the sequence of display connection to the system.
I'm executing Resolume Arena from a Python script so maybe a process with a system command to get output information and update the .xml of the Advanced Output of Resolume could fix the random index issue.
Also to reduce the complexity, for the permanent installation I'll disconnect the service monitor, to dial with less displays, and do the adjustments and maintenance with tight
Any idea on random multiple displays indexes when restarting a Windows computer?
Thanks in advance
Re: Display indexes in Advanced Output change after restarting Windows 10
You'd need EDID managers, like mentioned in this topic: viewtopic.php?f=12&t=17969
