Capture audio from HDMI input
ArthurTheTortoise
Post by ArthurTheTortoise »
I'm using a USB dongle to pull hdmi signal from my mac (running rekordbox) into my PC running Avenue. I can pull in video no issues, but I cannot seem to be able to pull in audio.
Audio is definitely coming through the device as I can pull through to OBS separately at the same time and it can also be used as a general audio input in the preferences. But I wanted to pull into resolume directly with the audio.
1. Is this possible?
2. is there a special setting etc in 'sources' to activate this?
Re: Capture audio from HDMI input
Audio inputs are only available for SMPTE and FFT.
Audio input to the composition via capture cards is not supported currently.
ArthurTheTortoise
Ok - thanks for letting me know!
