quicktime codec for resolume?
lucidhouse
Post by lucidhouse »
I'm keen to find out what the best quicktime codec is for resolume [high quality and performance]. At the moment I'm using avi codecs, but am planning to to convert files to quicktime because I want to make some clips available for download, so It would be better If this is a format that could be used on the diferent platforms.
thanks
[Edited on 10-11-2005 by lucidhouse]
MtB
Post by MtB »
good 'n old sorenson 3 is werkin fine :)
do not forget to de interlace your videoclips
and set keyframez to 1fr
bw
continuity-B
Post by continuity-B »
MJPEG is ideal
It's a spatial codec, not temporal, so all frames are 'keyframes' by default.
Generally use it at about 80% quality
lucidhouse
thanks for that, i'll do some tests...
yeah the mjpeg codec seems to be the most popular codec for quicktime these days and it,s working fine. mjpeg is also gaining momentum for the avi files formats allthough you have to buy one from Morgan or Pegasus.
