export video from 6.1.5
noBIGego
Post by noBIGego »
Hello - new to using Resolume - I plan to export audio reactive experimental video to then edit in after effects. When i am happy with content in output monitor I select the record button. I set the location for the recorded clips at 4k. so far these clips only last 3 seconds - how do i increase the duration of recorded clips to approx 5-8 mins? thanks!
James
Re: export video from 6.1.5
Try the latest version of resolume for this.
You can also try an external solution, like OBS, or a capture card.
https://resolume.com/support/en/6/recording
