Recording audio cut off after ~30 minutes
dgodd
Post by dgodd »
Unable to record a full set with the built in recorder without audio getting cutoff halfway through.
I believe the length of the audio track is 2147 seconds after being cutoff. Will try and get some more information in a few
Re: Recording audio cut off after ~30 minutes
What version of Resolume are you running? Revision number would be helpful. Thanks
dgodd
Post by dgodd »
7.3 rev 72441
dgodd
Post by dgodd »
I've never been able to record an hour mix. Using dxv format for recording too if that helps. It always seems to cut off audio at 2147 seconds
dgodd
Post by dgodd »
The audio track itself is fine - plays all the way through. However when checking the muxed recording - that's when it cuts off
How long is the recorded video track, the unmuxed one?
dgodd
Post by dgodd »
56:44
dgodd
Post by dgodd »
Just checked - audio cuts off at 35:47.475
Which leaves an audio track of 2147 seconds before cutoff
Can you update to the latest revision from our download page and try again?
If it still breaks, what are you recording settings, and how much free disk space do you have?
dgodd
Post by dgodd »
I will upgrade and report back.
This has been a consistent problem in the past as well. Disk space is not an issue - plenty of space on all drives.
Recording audio and video
DXV3 Codec
Normal Quality With Alpha
44100 Sample Rate
16 Bit Depth
This happened to be at 30 FPS 1280x720 but I have experienced at any resolution/fps that I've tried
