4K outputs look really Pixelated
Johnerstonrex
Post by Johnerstonrex »
Hey. I'm running Arena 6.1.5 on two separate PCs that are networked together. Both PCs use NVIDIA P4000s (2 each). PC2 looks fantastic. Clear, sharp images in 4K. PC1 looks really pixelated, and generally just kind of crappy in 4K.
The only difference I can find is that PC2 is using older drivers for the P4000's, where PC1 has the most up to date drivers. Try as I might, I cannot figure out why PC1 looks so badly. FPS looks fine, and all other settings are identical as far as I can tell.
Anyone else have this issue?
Re: 4K outputs look really Pixelated
Set Windows display scaling to 100% for your output displays ;)
