autopilot and start point
Roger74
Post by Roger74 »
Hi friends, can you hel me??? :cry:
How do this work?
I would set video project for cake mapping in autopilot.
How can do to set start point of second clip at half point of previous clip, and both it play together? (autopilot on and same layer)
I'm trying to do, but i found only way to do transition of second clip when first clip is ended
Thanks for reply
Re: autopilot and start point
Roger74
Post by Roger74 »
Hi Zoltan, if i well understood the question of post (same question of mine), this function not is possible to do in autopilot? Right?
He2neg
Post by He2neg »
Inside one Layer this is not possible...
But when you use 2 layers this can be done...
---------------Collom 1-------------------collom 2 -------------
Layer 1: -- Clip1 (10sec)--------------empty-------------
Layer 2: ---dummy clip (5sec)--------Clip 2-----------
When you now set both layers to autopilot and start the whole thing via the collom1. Then after 5 sec the Clip 2 will start playing.
In the Moment there cant be 2 videos in one layer at the same time... so you need to have 2
~Berlin~
Roger74
Post by Roger74 »
Hi He2neg
ok, transition time (setted from layer 2 windows parameter) can set at 10sec max, so if i need to play second clip after 15sec of first clip is played, not possible?
He2neg
Post by He2neg »
Roger74 wrote: Tue Feb 09, 2021 13:54 Hi He2neg
Nah... sure.... i guess you didnt understood me right The dummy clip is actuall a clip (i.e. a sloid color) and the duration of the clip is the "delay" time you want the 2nd clip to start...
This duration have no time limit.
when the first clip is 1hour and you want the 2cnd clip to start at 59:55 Then this is the duration of the "dummy clip" You start both at the same time via the collom. So the dummy ends when the first clip as still 5 sec to run...
~Berlin~
Roger74
Post by Roger74 »
Hi He2neg
thank so much
now i understood, great solution!
