NDI HX2
fiverecords
NDI HX2
Post by fiverecords »
A question. Can resolume stream the output in NDI HX2?
It is much more efficient with bandwidth than normal Ndi
Re: NDI HX2
More efficient = poor quality.
It can bring HX into Resolume, but I believe it's regular NDI on the out. How many streams are you sending out at a time? regular NDI with a 1080p@60 comp size should be about 250Mbps. That isn't too bad at all for networks. What are you trying to send NDI to?
