Resolume 7.3.2 Maintenance Release
No snazzy new features (yet) but bug fixes as far as my eyes can see.
Fix List
#10410 Crash renaming slice or lumiverse in Advanced output
#14401 Crash trying to draw new font
#14768 Crash trying to convert with start marker moved from 0
#14782 Crash showing file in explorer from other deck
#14788 Crash clicking on register offline with language set to Chinese
#14801 Crash loading GB18030 bitmap font in text animator
#14802 Crash playing AV file with wrong duration set in AVPacket
#14835 App fullscreen resize freezes Arena on Big Sur
#14750 BMD ATEM mini not working on OSX Big Sur
#14687 Transparency lost from camera capture, like Nvidia broadcast
#14793 OBS camera clip doesn't update texture
#14819 NDI clips don't get a server selected dropping them to your composition
#14823 Update NDI libs in installers
#10289 Audio Cracks when Starting and Stopping an Audio File
#11536 Some gifs don't play till the end
#13574 Identify display shows a different number than the output menu and ASS
#14445 Notify user when saving composition fails - Windows Controlled folder access
#14625 Play next clip breaks on clips which need to be relocated
#14652 Moving decks the deck list flashes positions
#14664 Setting Shortcut to Toggle, max value is kept from Value mode, slider shows wrong position
#14668 "No output device" selection resets to first in the list when audio device is added or removed
#14744 AV renders with files with different length audio and video streams get aborted
#14761 This composition has font-baseline wrong with 'Character'-animation
#14917 Text block line width is not breaking lines any more
#14767 Redo duplicate layer group column seems to break with two groups
#14825 Re-doing group column duplicate breaks if you undo too far
#14838 Relative play mode jumps to wrong position
#14843 Opening pre 7.3 compositions from the Composition panel, effects are not loaded
#14846 Recording with no empty column in layer 1 causes crash
#14857 AV recording only gets a 35 minutes long audio track
#14931 Prores 4444 XQ with alpha plays incorrect
#14374 Prores renders and recordings are not recognized properly by Adobe
Download
Select "Check for Updates.." in the Avenue or Arena menu and it will self-update. Or checkout the downloads page.
elbundlo
Re: Resolume 7.3.2 Maintenance Release
Post by elbundlo »
Thanks Bart, but this has caused my version to crash upon opening. Not good. What is going on?
elbundlo wrote: Fri Mar 12, 2021 12:33 Thanks Bart, but this has caused my version to crash upon opening. Not good. What is going on?
We found out via email, that the crash was on an 2011 macbook pro, not meeting the minimum specs.
