corrupt
Anonymous
corrupt
Post by Anonymous »
When recording i get corrupt avi files. Nothing is able to play them. Why should i do ?
this should be fixed with version 2.3! what version are u using?
continuity-B
Post by continuity-B »
that's odd
did you try opening then re-encoding them in an editor like premier?
Anonymous
Post by Anonymous »
i'm using 2.3
no...nothing can open these videos :(
DAS BEN
Post by DAS BEN »
after effects can. just ignore the error messages and skip the first frame.
tomperson
Post by tomperson »
Same problem here. After effects / Virtualdub won't open the file.
2.5Gb avi file @ 640x480.
