Slices
soundnut
Slices
Post by soundnut »
Its been awhile.. I'm creating a project w 2 screens (projectors) ea w 10 slices .
When I select slices made for screen 1 each slice displays properly when selected.
When I enable screen 2 and select slices for screen 2 it illuminates slices on screen 1 and screen 2.
I've assigned all screen 1 slices to use Layer 1 & assigned all screen 2 slices to Layer 2.
Also tried assigning all slices to composition and adding slice transformations on cliips/layers and composition. All methods always displays any selected slices on both screens
How do I make screen slices only display only their perspective screens?
Re: Slices
You mean the slice contents are going out to both display outputs?
Could you post a screenshot of your advanced output?
