Hello
is theres any option to create some custom thumbnails of resolume Compositions from where we can triger the Comps
						Custom thumbnail for OSC
Re: Custom thumbnail for OSC
Not yet.
Moved to feature requests
Are you wanting thumbnails of your "Clips" (Not comps) for an OSC controller? Something similar to CITP for Lighting Consoles?
I don't believe you can send images via OSC, so you would need to have a bunch of local images on your controller and then associate a clip's layer and column position with that clips name on the OSC controller (Not sure if any standard OSC controller software is that advanced), But I wouldn't think this would be something that would be on the Resolume side of things, more on the OSC controllers side of things.
