Big Sur Crash
John Servan
Big Sur Crash
Post by John Servan »
Hi I was trying the 7.3.2 on Big Sur but the program crash just after loading, something like after 5 seconds
Anyone ?
Thank you
Re: Big Sur Crash
Which Resolume version are you trying, and on which mac?
John Servan
Re: Big Sur Crash
Hi Tx for the reply
I'm on Big Sur 11.4 on a Mac Pro late 2013 (dustbin) with 64 g memory and two amd firepro D500 the program start but quit after 5 seconds with last version Arena 7.3.3_75993, any version in fact
I'm stuck
John Servan
Re: Big Sur Crash
I attached the log file
Resolume Arena log.txt.zip
(3.65 KiB) Downloaded 240 times
Re: Big Sur Crash
Can you try renaming the Documents/Resolume Arena folder, and see if that helps?
John Servan
Re: Big Sur Crash
renaming Resolume Arena to Resolume Arena ?
If I rename it for example Resolume Arena 7 it create again a Resolume Arena folder, and it still crash 5 seconds after the UI appears
Re: Big Sur Crash
Hmm, ok, could you send us the log again?
John Servan
Re: Big Sur Crash
here we go
(3.64 KiB) Downloaded 237 times
Re: Big Sur Crash
Thanks,
so weird that the log only has one startup logged. It should have all previous ones too.
Are you running Resolume as a guest user?
Do you get an OSX crash notification?
