Using Video Router with Live Webcam Feeds causes stutter
vectorfuton
Post by vectorfuton »
When using my webcams in a single cell, the feed is transmitted smoothly no problem. However, once I use a video router to try and take from this live feed, the picture often glitches and inverts itself vertically and flickers quickly. I've tried it on multiple cameras, and it is only doing this for live sources, not on regular video files or other sources. The glitch is only happening on the Video Router cell, the original cell remains clean.
Any clue?
Re: Using Video Router with Live Webcam Feeds causes stutter
Could you please send us the Resolume log file via the feedback tab in preferences?
vectorfuton
Have tried to repeat the issue, but is working fine for now. It has happened to me before though, so if it pops up again I'll send the log, thanks!
Thanks for the log,
Can you try updating the nvidia drivers?
You could also try to disable the DMA textures in the Resolume video preferences, maybe that helps?
