Splash Screen Locked Into Focus
Any chance we could remove the Splash Screen from being Locked into focus upon starting the app? Many times I'm trying to work in other areas of my PC and I can't see anything since the screen is locked into focus :)
vectorfuton
Re: Splash Screen Locked Into Focus
Post by vectorfuton »
Sounds similar to what I posted a while back viewtopic.php?p=81759#p81759 Unless you are talking about something different?
In any case, yeah, even in my less-loaded sets, the Splash Screen is still an annoyance which would be great to deal with.
Try adding --nosplash as command line argument when starting Resolume.
https://github.com/resolume/ffgl/wiki/4 ... ience-tips
Zoltán wrote: Tue Apr 06, 2021 11:22 Try adding --nosplash as command line argument when starting Resolume.
Amazing! Thank you
I'll be sure to keep the splash on during shows, but at home it can be a bit much at times :)
vectorfuton
The linked page suggests this is only for Arena. Correct? Or is this doable on a PC machine with Avenue as well? Cheers.
Menno
Post by Menno »
You can use the same argument for avenue. Note however that that the steps listed on that page page are for plugin developers. If you're not a developer you can just add the argument in the application shortcut.
