DMX Shortcuts for Transport Per Layer
rolandmc
Post by rolandmc »
Hello, is there a way to control transport speed, playmode, playback direction, etc per layer? I'm setting up DMX shortcuts and I'm finding out that I can only set up these transport controls for clips, and those controls control affect every clip as it is selected.
I'm looking to be able to control the clips on layer 2 independently from the clips on layer 1 via DMX shortcuts, is this possible?
Thank you
Re: DMX Shortcuts for Transport Per Layer
Give these a shot:
https://resolume.com/support/en/osc
[url]https://resolume.com/download/Manual/OSC/OSC%20list.txt[/url
Edit: Derp, sorry posted this in the wrong page lol
For Layer mapping be sure to enable Transport Controls under view and then you should be able to map each layers play direction, For speed you will need to use position or selected clip like Zoltan suggested.
Check the By position target on the DMX shortcuts: https://resolume.com/support/en/dmx-shortcuts
rolandmc
Post by rolandmc »
Perfect, thank you both.
rolandmc
Post by rolandmc »
On a related note... What about clip position in and out? Is there a way to map that by layer rather than by composition or selected clip?
rolandmc wrote: Fri Jan 28, 2022 23:10 What about clip position in and out? Is there a way to map that by layer rather than by composition or selected clip?
Currently that's not possible via DMX.
