Audio problem when control via OSC Master-slave
kevin
Post by kevin »
Dear,
I have 2 server with Master and Slave control via OSC, all comp in 2 servers same but when I play clip in Master, it will trigger slave play also but the audio have some noise or not clear in Slave server (audio in master still OK), I did not know why like that hope some master guys saw it before and solved can help.
Many thanks,
Re: Audio problem when control via OSC Master-slave
Have a look here: viewtopic.php?p=79966#p79966
Basically, your preset also sends the playhead position, which is not matching the position on the slave, so the audio is jumping around a bit.
