Using AKAI APC mini controller with Resolume 7.0
greenvillehughes
Post by greenvillehughes »
I want to use the AKAI APC mini controller with Resolume 7.0
The posts on this forum are about 3 years old, so I don't know....
Are there are any current issues or problems with using this controller with Resolume 7.0?
Has anyone tried mapping it with Resolume 7.0?
Do I follow the instructions shown in the Resolume Tutorials for MIDI devices or is there another way I need to do it?
Thank you for your help!
-Edwin
Re: Using AKAI APC mini controller with Resolume 7.0
Mapping in Resolume should be no problem: https://resolume.com/support/en/midi-shortcuts
The issue with the APC mini was firmware stability as far as I recall.
