NDI Audio
Re: NDI Audio
Not that I'm aware of. I would prefer multi channel audio support over NDI audio as you can use Dante at that point, or even a NDI to Dante conversion
Re: NDI Audio
Hey Arvol, may be that Dante or anything else may be a heavier lift, am certain simply supporting NDI uncompressed audio would be soooo simple, as NDI SDKs (the open source ones from NewTek Resolume most surely used) come with audio out-of-the-box. Almost seems like more work for Resolume to NOT have supported itArvol wrote: Thu May 27, 2021 19:20 Not that I'm aware of. I would prefer multi channel audio support over NDI audio as you can use Dante at that point, or even a NDI to Dante conversion![]()
Re: NDI Audio
As of right now, I don't think there is a way to bring in ANY audio from ANY sources. The only way to get audio in is to use the external FFT that you can setup in the preferences. I know you can convert NDI to Dante and then use Dante as your external FFT. You could probably even convert NDI to a local playback source via virtual hardware and eliminate Dante all together.
The bigger picture issue I see here is that there is no audio support for sources and not just a NDI exclusive deal here. I think multichannel audio will need to come before allowing sources to bring in audio, but that's just my 2 cents. For now, I know I can bring in NDI audio with some work arounds, not ideal, but do-able
