I just upgraded Arena via internal update function to Arena 7.4.0 rev76322 which is the same Version as on the resolume website, which is described to include the new "wire" tool (at least as a demo I guess).
Unfortunately I cant figure out how to start wire !?
Please help
						Wire not found !?
Re: Wire not found !?
PC: Start menu> Resolume Wire
Mac: Finder> Application> Resolume Wire
Look for the orange "W" logo.
if it's not there you might try re-installing
Can you also search for "Wire" in your OS's search function?
You can always use the installer from our download page if the auto updater failed.
Thank you guys !
I was blind , oversaw the programm icon, since I was thinking it has to be startet inside Arena.
best regards
best regards
