How to use a compiled wire file in Resolume?
taratoga
Post by taratoga »
Cant figure it out to use a compiled wire file. I did it by using the patch "NeonCircuits" compiled it and wroteit to one of my local drived. I can see that there is a file with the name "NeonCircuits.cwired" I compiled it non editable. But cant find any dialog to use it in Resolume...
Re: How to use a compiled wire file in Resolume?
Try dropping it onto the Resolume UI ;)
taratoga
Post by taratoga »
Did it but no sucess... Have attached a zipped mp4 file
WireToResolume.zip
(2.11 MiB) Downloaded 564 times
Now look in your FX or sources tab and it should be there. is the file you installed a fx or a source? (needs to be specified in Wire when being built)
taratoga
Post by taratoga »
It is set to source, but it doest work for me. Have Tried everything.. :cry:
Could you send us the patch to mail@resolume.com and the Resolume log file using the feedback tab in preferences?
If you're trying these, they should be listed in Sources panel. Scroll down a bit, they won't be in the Wire group.
Code: Select all
[2021-06-26T15:04:20.523+02:00]   INFO:     Register Wire Patch C:\Users\Public\Documents\Resolume Wire\Patches\Test.cwired
[2021-06-26T15:04:20.606+02:00]   INFO:     Wire patch is registered as Source Test ( Test )
[2021-06-26T15:04:20.608+02:00]   INFO:     Register Wire Patch C:\Users\Public\Documents\Resolume Wire\Patches\NeonCircuits.cwired
[2021-06-26T15:04:20.689+02:00]   INFO:     Wire patch is registered as Source NeonCircuits ( NeonCircuits )
taratoga
Post by taratoga »
Thank You .. Jap I found it out.
Kind regards
taratoga
taratoga
Post by taratoga »
Ok what I also found out is this behaviour:
If I define a path in the wire compile dialog it is not persistend.
For example:
The path of the Wire sources in Avenue is:
G:\eigene Dateien\Dokumente\Resolume Wire\Patches\TestMidi
This path I cannot influence...
The path of the Compile in Wire is:
Because it is not persistend I have to change it each time before Compile.. ;-(
Yes, Resolume loads patches from these two folders:
c:/Users/Your User/Documents/Resolume Wire/patches
This is the folder Wire saves patches to
and
c:/Users/Public/Documents/Resolume Wire/patches
This is where compiled patches go, and also where patches you drag to Resolume get installed to.
Keeping the path ensures, that Resolume can find your patch.
