Composition speed bug R7
cuesynchronizer
Post by cuesynchronizer »
hi guys
i have a composition speed bug that basically randomly changing the composition speed mid show
without showing any change in the composition speed value
lets say its says 1s (base value) and it was for the past 2 hours but now its 5x the speed but still showing 1s
any ideas ?
will be amazing to solve it
thanks in advance
Re: Composition speed bug R7
Which 7.x.x version are you using?
Could you please send us the Resolume log file via the feedback tab in preferences, after this happens?
cuesynchronizer
hi
its happened in 7.1 and 7.4
and yes i can send the log next time its happen
i hope it will help .
Thanks,
Are you using an external sound card, or Dante?
