Kona5 4k output question
LegitJesseee
Post by LegitJesseee »
Hey guys,
I am using Resolume Arena 7.4.1 on an iMac Pro with output via an AJA Kona5 card (4k firmware). I'm doing an led wall configuration where I need to output a 4k canvas, so my goal is to output a single 4k sdi from the kona to my processor. For some reason, I cannot get Resolume to show a 4k resolution in the "video format" tab of advanced output.
Is this a bug, or can the kona5 not output a single 4k link from resolume?
p.s I was able to somewhat get it working by doing a quad link 4k setup where each port was 1080p, but the sdis are not synced and it causes bad taring. I really want to get a single 4k link working if possible
plamen
Re: Kona5 4k output question
Post by plamen »
Bumping this because I am running into the same issue on my end.
No matter how many settings I adjust in the AJA Control Panel, opening Resolume always switches the card back to 1080p.
Sorry, 4k resolutions are not supported currently via AJA.
viewtopic.php?p=83589#p83589
Eledtech
Post by Eledtech »
i could get working 4k with one 12G output.
just install 8k firmware.
unfortnatly it is not possible to do a 8k output with 4x12G outs.
resolume seems not to support it.
i just bought the card in hope it works better than a bmd decklink 8k, but its worse. :(
Visual and led designer at eledtech and aseven night club/Berlin.
