I have Resolume Arena paid until last update 7.3. Arena 7.3 is the version I use.
Online it is said:
"Wire is made to work with Resolume, both Arena and Avenue are compatible with Wire from version 7.3 and up."
(https://resolume.com/support/en/wire-introduction?wire)
That is why I payed for Wire. I have no money for buying an update for Arena to last recent version.
Apparently it is not possible to install only Wire. So I downloaded the recent combination (Avenue, Alley & Wire) to install Wire and keep my 7.3 Version auf Arena.
Now, after installation, Arena doesn´t start any more (Mac OS X 10.13.6). Opening Arena in Terminal-App gives the following:
objc[717]: Class View is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75360) and /Library/Application Support/Resolume/lib/libwire.dylib (0x123ad0fd0). One of the two will be used. Which one is undefined.
objc[717]: Class AVFFileSystemResourceLoaderDelegate is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a753b0) and /Library/Application Support/Resolume/lib/libwire.dylib (0x123ad1020). One of the two will be used. Which one is undefined.
objc[717]: Class ReaderInternal is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75400) and /Library/Application Support/Resolume/lib/libwire.dylib (0x123ad1070). One of the two will be used. Which one is undefined.
objc[717]: Class CaptureDeviceAVFDelegate is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75450) and /Library/Application Support/Resolume/lib/libwire.dylib (0x123ad10c0). One of the two will be used. Which one is undefined.
objc[717]: Class MenuItemView is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75180) and /Library/Application Support/Resolume/lib/libwire.dylib (0x123ad1110). One of the two will be used. Which one is undefined.
objc[717]: Class View is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75360) and /Library/Application Support/Resolume/nodes/wire/slice.dylib (0x19f829b68). One of the two will be used. Which one is undefined.
objc[717]: Class AVFFileSystemResourceLoaderDelegate is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a753b0) and /Library/Application Support/Resolume/nodes/wire/slice.dylib (0x19f829bb8). One of the two will be used. Which one is undefined.
objc[717]: Class ReaderInternal is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75400) and /Library/Application Support/Resolume/nodes/wire/slice.dylib (0x19f829c08). One of the two will be used. Which one is undefined.
objc[717]: Class CaptureDeviceAVFDelegate is implemented in both /Applications/Resolume Arena/Arena.app/Contents/MacOS/Arena (0x105a75450) and /Library/Application Support/Resolume/nodes/wire/slice.dylib (0x19f829c58). One of the two will be used. Which one is undefined.
Subscriber::receive(): Shutdown was requested
Segmentation fault: 11
logout
Saving session...
...copying shared history...
...saving history...truncating history files...
...completed.
Wire seems to be working properly.
I would really thank you for any solution, to let me run Arena 7.3 and Wire on the same system.
Thanks a lot
