Transition time on clip or column level
vj harald
Post by vj harald »
Hello community,
I am triggering cues by launching columns.
My question is: Is it possible to set separate transition times for different columns or clips.
The only way i found is to set different opacity envelopes for clips.
It works, but is a bit inconvenient if it has to go fast and you have many clips ;-)
Perhaps there is a better solution.
All the best,
H.
Re: Transition time on clip or column level
Try this app, it can set the transition time for your layers while also managing the column launch for you:
http://palffyzoltan.hu/?url=controller
vj harald
Post by vj harald »
Thanks a lot Zoltán !
This App sounds promissing.
Will definitly check it out on my next project.
All the best,
H
