Custom OSC out
ibox
Custom OSC out
Post by ibox »
Hi!
I want to send a custom OSC command to a lighting console each time I trigger a clip, this way each clip is accompanied with a different lighting.
I managed to send the custom command, but I can't set the value, when the clip is deactivated the command is sent with value 1 and when it is activated the command is sent with value 3. And the console works with value 0 & 1.
Also when I change the command to a custom one the clip still shows the old command in white letters, instead of the custom command.
How can I define the custom value in addition to the osc arguments?
Many Thanks
Re: Custom OSC out
Clip trigger sends 5 states,
0= empty slot,
1=clip present, not connected or previewed
2=clip previewed, but not connected
3=connected, but not previewed,
4=clip previewed and connected.
Arguments can't be changed currently.
The highlighted items show the expected input command for the item, these are hard coded, and can't be changed.
