the best way to build a pc to work with a large video wall is it?
nvidia or amd?
to synchronize the quadro outputs, should mosaic be turned on?
best way to build a pc to work with a large video wall?
Re: best way to build a pc to work with a large video wall?
there are very large video walls out there with 1920x1080px in total....then you don't need to sync anything.....and you are totally fine with a midrange laptop.... what resolution are you thinking of?
Do you like outlines? Easy Outliner on Juicebar Re: best way to build a pc to work with a large video wall?
What is "Large"? Some people consider a 16' wide wall "Large" (I don't). What is the pixel density of these "Large" walls?
