Improvements in next versions
illy
Post by illy »
Hey, i've been using reso 2.3 and got some sugestions. Sorry for my english.
- the clock, it really freaks me when i see the hour and the party is boring, can u do something like that:
the clock is in the place of the resolume 2.X txt, and when i roll my mouse over it, then the clock apears?
- the efx, and especially the three general efx, can it be like: when i load the efx the alpha value is 0? its quite annoying when i put and effect and it goes online instantly, i know that i can match the apearing with the beat, but i like to make a long transitions of the effect
- the thumbnails. when i have a black first frame, the thumb nail is black, its kind reorganising me, maybe add the filename under the thumbnail or a orange or other color border around the thumbnail of the clip that is on one of the layers?
i hope i helped a little bit and my request were not on the wishlist :)
thank you
continuity-B
Post by continuity-B »
As far as your second request...
If you hold [alt] while dragging effects on they default to 'zero' values (in the manual)
illy
Post by illy »
oh, thanks, i read the help file, but should have missed this one
more about your second request. you can also set the effect parameters the way your want them (including the opacity) and then click 'save' (the floppy icon). now the parameter settings are saved and when you apply the effect again the settings will start with these new innitial values.
