360 Dome VJing
jim
360 Dome VJing
Post by jim »
Has anyone got experience using Dome Master format or any 360 Dome projection experience?
If so are there any suggested resources?
Would people be interested if I documented process of setting up Resolume to VJ in 360?
The dome I have got residency Vjing on isn't going to be built till November, what I'm currently trying to work out is best way to preview content. I am shooting a whole heap of old school VJ type content like power lines in 360, which I know will layer well. Any suggestions or guidance welcome.
Thanks,
Jim
Re: 360 Dome VJing
Nestmap is a great companion for Resolume if you're into dome mapping http://nestimmersion.ca/nestmap.php
jim
Re: 360 Dome VJing
Post by jim »
Zoltán,
Thanks for that, it looks like a gold software, I have a tech taking care of projectors, But I actually think it would feel better if set up the mapping with something like this software so I know the vibe of the pixels.
BTW, after our chat over email, I have been trying to throw myself into the forum again.
As I have got this gig now, I'm focusing my wire time into making 360 stuff. And I am want to build a 360 remapper, between Equi-Angular Cubemap; Cube Map and Equirectangular and any other formats you find 360 content in.
I have a insta360 oneR so shooting whole heap of classical vj subjects like powerlines that I know, can layer nicely with a threshold or just key, saying that I feel I should maybe prep in post abit.
Jim
Re: 360 Dome VJing
360 stuff would be great to see being done in Wire.
For now I'd say the ISF node is the way to go there probably.
gpvillamil
Re: 360 Dome VJing
Post by gpvillamil »
DanielArnett
Re: 360 Dome VJing
Post by DanielArnett »
gpvillamil wrote: Tue Sep 28, 2021 16:18 Have you looked at this?
https://github.com/DanielArnett/360-VJ/releases
I just pushed an update to this, now it should work with the latest versions of Resolume. Now it's all one effect for converting between different projections. I've actually even done the math for EquiAngular cubemap, but that's not in there right now. If someone has an urgent need for me to add that in just make an Issue on GitHub.
zaniz
Re: 360 Dome VJing
Post by zaniz »
take a look on Blendy Dome Vj. you can send your content to the dome projectors from Resolume, VDMX, Modul8…
https://blendydomevj.com/
