Wire - Frame Count
hepi.yellow
Wire - Frame Count
Post by hepi.yellow »
The Issue
I am trying to write a Strobe patch, and in order to get constant strobing in high speed, I want precise control of each frame.
For example:
frame 01: black
frame 02: white
frame 03: black
For this I need to know the frame count.
Re: Wire - Frame Count
Wire updates Signals values on every rendered frame, so you could use an OnChange node on a continuous signal for example from a Transport Time and feed that into a Counter.
--begin-wire-patch--
435.3ocoS1zaiBCDF9uR0bFKYrIlOtkBgq8RuU0CDvIXUhcjwzcqh3+9NFnoqTooRsb.aOy6L1yiGeApMZsr1oL5dH6oKvAq4DNIL.5knuld34.vYPSr.PoOO3nvyiAWEhVMCtYyKB43nUc7nzhJQiZSiDS9EHz+qxgN2O3lLMF.6MC9cA8zJUGacPVHUD.+Q03Zw4oaBf+BYLNl027qivXp6p5mBQ0.YPbrHMlI1PRREkjnbQAYa4lHBeifEUlriwKRf.3UosGKSHiNkAS8KXrupZjFzYsoyXw0GvOQEkNYR26pztkyYqpoQhQ+juhpNIQwOZqz8mMV2cOpPCnH1mpvElQbucV5WNONOfmoptA+xCclJmOApo8rdNzEs5gS6QVdUc33pXiS+D0hhYSTiwR9ZpsSbOiDkxBIokkQj764aoaiSPuE+Rp8d+xGkxbcdsRniqC1Gz2k2VoONwT9ZL8GSo0ZtdGSb5MZtxKRxIQ6DBRhfxIbZXXQjfkRE4+VLYk8R2+2br754ZsnG55v7hQXc2hldIxyeshvwOdZ9ca252L4HPcnVua7XaFry2Bii+CVTY0E
--end-wire-patch--
