Hello,
I have downloaded the trail to learn before I buy. However I cant save. I am getting this error:
"Saving of Composition was unsuccessful, please check file permissions!"
Resolume is not creating a directory in my documents.
Ive tried reinstalling and tried different versions, same issue.
Does anyone know how I can fix this?
Thank you!
trillionmaze
Re: Saving of Composition was unsuccessful, please check file permissions!
It's probably a virus scanner or windows ransomware protection preventing Resolume from writing into your docs folder.
Try adding Resolume to these as exception.
trillionmaze
It ended up creating a directory after un and reinstalling many times.
Will look into virus protection.
Cheers
Cheers
