Couldn't find any info on this and not sure if I'm just missing that bit button right in front of me or something : P
So I have a whole bunch of mapping done in the advanced output, lots of individual slices coming from many layers. I've recently added a bunch of new clip layers to my composition and it's pretty unorganized now.
Problem is that when i change the hierarchy of the layers in the composition, the input sources for slices in the advanced output change accordingly. I guess the slice inputs are just looking at the layers in a 1, 2, 3, 4, 5, etc. way, instead of locking on to a particular layer.
Is there a way around this? Like being able to lock slice input sources to a specific clip layer, regardless if you change the hierarchy of the layers in the comp? Or do i need to just manually reassign each slice input source if I rearrange the layout of my layers in the comp?
Many thanks
