Organise generators into folders
joelle
Post by joelle »
Hello! New to the forum and to Resolume. I'm currently a VDMX user using Vuo, and am considering making the switch to Resolume. As Resolume only supports Vuo as FFGL plugins, I was wondering if it is possible to organise generators into folders?
I exported a Vuo comp called " Grid_ Space" as FFGL and it's in a folder in ~Library/Graphics/FreeFrame Plug-Ins/<Folder name> however it is still showing up in the root folder of generators in Resolume. See attached image.
Is it possible to create folder structures? As I'd need to do this to organise the various different projects if I were to export all my Vuo comps as FFGL.
Re: Organise generators into folders
Adding folders is not possible currently, but you could name your plugins to start with the same string.
That way, they would be in a group together.
