Resolume 7.6 Released!
MarkyMark
Post by MarkyMark »
This update takes the customization of Arena and Wire to a whole new level.
We've got undockable panels, customizable interfaces, color coded nodes and multi-screen support for you.
Besides numerous bug fixes we've added a brand new video exporter to Resolume Wire.
Custom Layouts
We’ve taken the layouts to a whole new level with this update.
Arena, Avenue and Wire now have undockable panels.
This feature lets you create custom multi-screen interfaces with ease.
Wire now has moveable panels, so you can create custom UI’s that fit your needs.
Colored Nodes
To continue this wave of customization, we would like to introduce you to colored nodes.
Color coding nodes helps you to organize your patch.
In addition to this we've given the comment node the option to be hollow.
This helps you to group nodes together, all in the name of beign organized!
Video Exporter
You can now export the video from your patch directly from Wire.
After you’ve made your latest Wire masterpiece you can easily export it to a video file using the brand new Video Exporter. The Video Exporter inherits all it's features from the Arena/Avenue exporter, so expect all your favorite codecs to be included.
Dashboard
Wire has a new tab called the Dashboard.
In the Dashboard you can reorder your input nodes.
The order you make in the Dashboard will be the order that shows up in the Arena/Avenue interface when running your patches.
Wire Fix List
#15722 Crash trying to open patch from Host
#15750 Video Exporter
#15762 String node float precision maxes at 6 decimals
#15778 Pack node upgrade by allowing composited inputs
#15856 Some compiled patches make Arena crash on startup
#15878 Directory watcher doesn't notice patch changes, when using Russian patch names
#15889 Time, SystemTime and Date have no suggestions
#15811 Trigger delay sometimes outputs twice
#15901 Removing Bool in Float path breaks connection
#15932 Average on multichannel texture goes to Alpha gradually
#15949 Crash with midi feedback on IAC driver
#15953 Midi Bank select support
#15962 Crash deleting Onchage in some patches
#15963 Node search result now order from more relevant to less relevant
#15964 Add aspect ratio information to the patch info node
#15999 Print Node now supports OSC messages
#16010 Loading tutorials and examples is now done asynchronous, decreasing boot time
#16013 Midi Write nodes can say unknown or no options on event input out of the range of int 1-16
#16023 Show MIDI messages in the Print node
#16086 Comment Node Outline/Transparent option
#16231 Not Equal node is now correct for float2, float3, float4
#16259 Replace Wire Inspector panel with separate Patch and Node panels
#16331 Wire crashes when enabling vsync after monitor panel drag
#15843 Span with size 1 thinks it is instanced
#15890 Gradient Palette, Linear and Sequence are missing from suggestions
#16055 Wire crashes using text render with lots of installed fonts
#16238 Transform node in texture mode, you need to multiply anchor x by aspect ratio to get expected results
#16292 Resource is not released when loading a different patch
#16321 Wire crashes with long inputs in ISF
#16438 OpenGL Error when unpacking DXV files
Avenue & Arena 7.6.0 Fix List
#14495 Paste audio effects not redone.
#14765 Clip toggle OFF doesn't respect beat snap
#14823 Update NDI to v5
#14979 Duplicating slices when you have already a lot, changes slice's and other slice's look
#15140 BPM synced params with start set to clip trigger, can get out of sync with clip transport set up the same way.
#15888 Option to disable update checks
#15910 Resolume doesn't reconnect to Syphon inputs
#15977 Universes span back to to S0:u0
#15991 High CPU in handling lots of DMX input
#16028 Some Solid color sources load saturation at 0 instead of the default 1
#16037 Rendering image sequence clip, only first frame is included in the render
#16115 Panels can get placed to the wrong place moving them around
#16122 8k options missing for decklink 8k capture card
#16144 Update minimum requirements to macOS 10.12
#16152 Slice outlines and corner handles are not aligned at high zoom
#16250 Sort Advanced Screen Setup presets by name
#16379 Patch installation fails if the shared Patch folder doesn't exist yet
#16409 Effect in panel doesn't resize when loading presets
Avenue & Arena 7.6.1 Fix List
#16449 Crossfader Fade(legacy) stops fading mid progress, after clicking A or B.
#16461 Crash removing all colors from palette
Download Resolume 7.6 now!
goblin@nurbs.ch
Re: Resolume 7.6 Release
Post by goblin@nurbs.ch »
Wow! Amasing update.
Always i did miss some features you bring an update. Can You read minds!? :P
Thank you MarkyMark
Custom Layouts
AWESOME!!!!!!
MarkyMark
Re: Resolume 7.6 Released!
Post by MarkyMark »
Thursday we'll do a Live Stream on Resolume 7.6.
Come and join us as we go through all the new features in Arena and Wire.
The Resolume Team will be in the comment section, ready to answer your questions.
