Skype NDI resolution change
Luk
Post by Luk »
Hi everyone,
I will run a theatre show soon including several Skype NDI feeds which seems to work without any issues so far, only thing is the change of resolution in case the bandwidth of a skype participant is changing!
Is there any way of fixing and locking the resolution and scale of the NDI video in Arena so this won't happen? Is this simply done by fitting/scaling manually or will it change once it receives that other resolution input from the sender no matter what? I know there is a workaround in OBS so this won't happen, any chance that is possible in Resolume, any experiences with that?
I would be grateful for any tip, thank you so much!
Best,
Luk
Re: Skype NDI resolution change
Try the Layer's auto size option: https://resolume.com/support/en/layers#video
