what about resolume on my gameboy
Anonymous
Post by Anonymous »
hi
if its possiblle to install some emulator of my gameboy color and than install resolume???
:cool:
continuity-B
Post by continuity-B »
Yes, but you must have at least Gameboy Color, Resolume will NOT run on Pocket or Classic versions. If you have an Advance you can make use of the new widescreen interface and higher resolution output. Two or more Gameboys can be linked using 'Link Cables' enabling you to mix the output from multiple Gameboys without the need for a hardware mixer, although this feature is buggy.
While it will run fine, there is no performance increase if using a DS as Resolume does not as yet make use of the GPU to render video, although a version is planned sometime next year. However, the touchscreen can be used as a midi controller.
VJzoo
Post by VJzoo »
id love to give this a go, any idea how its done?
levon
Post by levon »
the one problem with the DS is that like the ibooks, you have to install the dual screen hack to get different things displaying on each screen.
Psykopulp
Post by Psykopulp »
i'm sorry but i'm not sure i understand this thread... Is there a resolume on GBA ?? or any other portable platform ? (PSP might be sweet ^__^')
I'm selling backup devices and for GBA i've got a SD adapter that support 1 gig SD, it would be sweet to set up the DS touchpad scratch pad ^____^'
Anyway please update me on this matter i'll be happy to contribute to the portability on other systems.
Anonymous
Post by Anonymous »
ya mad skanka
je's havin a larf innit :P
Anonymous
Post by Anonymous »
yes it works
fantastic thx for the help with the gameboyscreenhack.....
:D
Anonymous
Post by Anonymous »
Anonymous
Post by Anonymous »
How do you connect the gboy to the pc?
Anonymous
Post by Anonymous »
how do i install resolume on a gameboy?
do i need some emulator?software?
