Crossfader midi mapping
khzano@gmail.com
Post by khzano@gmail.com »
Hello :)
Noticed that the crossfader on my akaiAPCmk2 was not working but its midi map was correctly set.
then tried to erase mapping and remap but still to no effect.
currently running latest version of Arena.
Also had experienced a crash while saving a UI layout and sent ticket to dev
anyone else have these issues ?
Re: Crossfader midi mapping
Crossfader midi map will be fixed in the next release again.
Can't see a crash report with your email, did you fill out all the fields in the reporter?
khzano@gmail.com
Unfortunately i did not add mail and just sent it but it was this morning and most likely due to a pending windows update.
I failed to reproduce this crash after restarting windows and it hasn't occurred since.
Hmm, ok, did you add a description to the report we could search for?
khzano@gmail.com
It totally got me by surprise and ended up just pressing send report like a dummy.. ( it was probably a loooong while since ive had Arena crash)
I Promise to include more info next time something like this happens
Had a look at the report IP countries, I see two reports from Israel.
Both seem to be related to a layout issue which we're working on.
If the crash happened opening up a dialog, or window, try to start over from the Default layout.
Morph
Post by Morph »
Zoltán wrote: Wed Nov 10, 2021 08:04 Crossfader midi map will be fixed in the next release again.
Awesome! I thought it was something I was doing wrong :)
