Slow on Resolume
chidanandbj
Slow on Resolume
Post by chidanandbj »
Hi tried to play mp4 format video on resolume 6, Audio was delayed with video. is it compulsary to conert to DXV or resolume 7 will be the solution for mp4 videos smooth play.
Re: Slow on Resolume
MP4 is a highly compressed keyframe based format, and it's not recommended to use with Resolume.
​It's being decoding on the CPU, so playing multiple 4k mp4 files at once can have a big hit on your CPU usage for example.
​We recommend to use DXV encoded video clips with uncompressed audio for best performance. DXV can be decoded on the GPU, taking the load off your CPU.
​​You can use Alley, our free encoder and player to convert supported media formats to DXV.
Alley is bundled with Resolume 6 and up, but you can also get it as a standalone installer from our download page. http://resolume.com/download
Resolume installers also install a plugin for Quicktime, and Adobe products so DXV should also show up as an option in the Quicktime formats, or stand alone in the Format list - depending on which converter you use.​
