Moving pixels in advanced output.
nmugnaini
Post by nmugnaini »
Hey hey, I asked this question on the Facebook group but little solution.
I would like to reconfigure the mapping of my lighting pixels throughout the show but use the same content. Is the a way (or work around) to change the presets in the advanced output menu? To be clear I'm only using lumiverses and not slices.
I've tried adding same DMX fixtures to different lumiverses, which would be a good solution but I'm getting conflicting data out that makes a flicker.
Re: Moving pixels in advanced output.
Did you find a solution on facebook?
Setting your fixtures to HTP merging mode could help, if they support that.
