Is it possible to export video with map
Melania
Post by Melania »
Hi, I have created my project and a map for my surface. Is it possible to record and export with the map embedded in the file so I can transfer the project over to a usb to use in a media player?
Thanks for any tips.
He2neg
Re: Is it possible to export video with map
Post by He2neg »
sure you can just record the compositon output ;)
Slice Transform is your frind to transform the composition to match your output mapping...
~Berlin~
