Smpte performance issues
Bassindaniel
Post by Bassindaniel »
Hello!
Having a weird performance issue.
Running Resolume Arena 7.7.1
Comp and clip resolution is 15000x3000
When playing clip in “timeline” method - Resolume output is solid 50 fps.
When switching to smpte, fps drops sometimes below 25fps. Average is 35~.
Tested on a 25fps and @50fps clips. Both DVX.
SMPTE input tested via motherboard sound card and focusrite 2i2 3rd gen. Same result in both of them.
Please help me solve it.
Thanks,
Daniel.
Re: Smpte performance issues
What kind of machine are you using?
Bassindaniel
Actually i did tested it on two different systems.
One is a desktop pc.
i7 8700k, gtx 1080, 32 ram
And the other one is a laptop.
i7 11th gen, rtx 3070, 32 ram
I think the issue is with the file resolution, and the way how SMPTE playback gets the frames from the file.
I'll make a ticket, maybe we can improve this somehow.
A smaller resolution file in the same composition should be performing better.
Bassindaniel
Thanks a lot.
